[gdal-dev] gdalWarp generates a black image when I use the outputBounds option
jratike80
jukka.rahkonen at maanmittauslaitos.fi
Mon Feb 17 12:01:17 PST 2020
Well, based on the errors I tend to do I am pretty sure that the bounds are
not OK. Test data can be what ever raster, or you can use gdal_edit and
paint your original image into totally red or what ever color you want. But
I am sure that you can resolve your problem also by your own with some
thinking and testing.
-Jukka-
gustavorsantos wrote
> I am converting the Tiles Map Service coordinates to the ESPG:3857
> projection. I have pretty sure that the tiles coordinates are between the
> master image's bounds. I use the command line gdalwarp using the -te flag
> but I have the same output.
> Sorry, but I am working with private data and I don't know where you can
> find similar data.
> Anyway, thanks!
> Gustavo Santos
> Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
> gdal-dev mailing list
> gdal-dev at .osgeo
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
