[gdal-dev] How do I install GDAL on Windows 10?
Jeff McKenna
jmckenna at gatewaygeomatics.com
Tue Feb 25 05:12:15 PST 2020
If you are looking for a simple zipfile, you can download MS4W
(https://ms4w.com/) which contains GDAL 2.4.4 and Python 3.7.5 -
GeoPandas hasn't been added yet to MS4W, but there is already a ticket
filed so it will be added to a future version soon.
Some steps for you:
- extract MS4W to drive root, so after extraction you have C:/ms4w
- open a command window and cd into /ms4w
- setenv.bat
- gdalinfo --version
You can then get more assistance from the MS4W community at
https://ms4w.com/forum/
-jeff
Jeff McKenna
MapServer Consulting and Training Services
https://gatewaygeomatics.com/
On 2020-02-25 1:59 a.m., /dev /local/ca wrote:
> I want to install and use GDAL on Windows 10.
> I don't know what 'conda' is, I don't care what it is, and I don't want
> to install it and screw up my machine.
> Ultimately I want to install 'geopandas', but it has a requirement of
> 'fiona', and 'fiona' requires 'GDAL' so I need to figure that out first,
> then I need to figure out how to install 'Rtree' which has a dependency
> of 'spatialindex', so after this will figure out how to install
> 'spatialindex', then figure out how to install 'Rtree', then try again
> and see if 'fiona' will install and then after that try 'geopandas' again,
> but for now, the first step I see is 'GDAL'.
