[gdal-dev] ogr2ogr command to coordinate transform using NTv2 grids in GDAL 3+
Pedro Venâncio
pedrongvenancio at gmail.com
Fri Feb 28 08:04:16 PST 2020
Thank you very much Even!
As usual, faster fix was completely impossible! :)
Best regards,
Pedro
Even Rouault <even.rouault at spatialys.com> escreveu no dia sexta, 28/02/2020
à(s) 15:51:
> Pedro,
> > I'm trying to make transformations with ogr2ogr, using NTv2 grids, in
> > GDAL/OGR 3, and it does not work.
> > The command I was using in GDAL/OGR 2 is
> > ogr2ogr -s_srs "+proj=tmerc +lat_0=39.66666666666666 +lon_0=1 +k=1
> > +x_0=200000 +y_0=300000 +ellps=intl
> +nadgrids=C:\Users\PedroVenancio\AppData\Roaming\QGIS\QGIS3\profiles\default
> > \python\plugins\ntv2_transformations\grids\DLx_ETRS89_geo.gsb +wktext
> > +pm=lisbon +units=m +no_defs" -t_srs EPSG:3763 -f "ESRI Shapefile" -lco
> > ENCODING=UTF-8
> > D:/Testes/postos_vigia/postos_vigia_rede_nacional_3763.shp
> > D:\Testes\postos_vigia\postos_vigia_rede_nacional_20790.shp
> > and the result in GDAL/OGR 3.0.2 or 3.0.4 is
> > ERROR 1: Failed to reproject feature 0 (geometry probably out of source
> or
> > destination SRS).
> > ERROR 1: Terminating translation prematurely after failed
> > translation of layer postos_vigia_rede_nacional_20790 (use -skipfailures
> to
> > skip errors)
> > This command works well in GDAL/OGR 2.4.0 and 2.4.2.
> Arg, I found this was a bug of PROJ >= 6. I've just submitted a fix for it
> in
> https://github.com/OSGeo/PROJ/pull/1998
> The issue came from using both +nadgrids and +pm, which wasn't handled
> correctly, and resulted in grid transformation being done with longitudes
> expressed in Lisbon prime meridan instead of Greenwich
> > And where can I find documentation about the WKT2 string describing the
> > CoordinateOperation to use in -ct?
> Create coordinate operations in WKT2 can be really tedious. The best
> reference
> is probably the standard itself:
> http://docs.opengeospatial.org/is/18-010r7/18-010r7.html
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200228/fbe5e7bf/attachment.html>
