[gdal-dev] netcdf warnings
Joaquim Manuel Freire Luís
jluis at ualg.pt
Sat Feb 29 11:50:44 PST 2020
There are a couple of issues that show when I run this test case.
First is that ERROR 3
$ gdal_grid -ot Float32 -txe 0.000000 10.000000 -tye 0.000000 10.000000 -outsize 201 201 -a nearest lixo.vrt junk.nc
Warning 1: Several drivers matching nc extension. Using NETCDF
0...10...20...30...40...50...60...70...80...90...100 - done.
ERROR 3: An attempt to read an undefined ID from virtual variable collection was made
Repeating the command (that is, overwriting the grid) shows more warnings, namely the "dimension #1 (lon) is not a Longitude/X dimension"
Warning 1: The dataset has several variables that could be identified as vector fields, but not all share the same primary dimension. Consequently they will be ignored.
Warning 1: dimension #1 (lon) is not a Longitude/X dimension.
Warning 1: dimension #0 (lat) is not a Latitude/Y dimension.
0...10...20...30...40...50...60...70...80...90...ERROR 3: An attempt to read an undefined ID from virtual variable collection was made
Which also show in gdalinfo
$ gdalinfo junk.nc
Driver: netCDF/Network Common Data Format
I see that the x,y coordinates are always named "lon,lat" but data is not in geographics those names are not true. In GMT we call them "x,y" what data represent cartesian units or "lon,lat" when they are geographic. As a consequence of this, gdalinfo report those "not a Longitude/X dimension" warnings for the former case when the nc grid has not an "spatial_ref" attribute.
The data used in this example is attached
Joaquim
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200229/c3b50fec/attachment-0001.html>
Type: application/octet-stream
Desc: lixo.vrt
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200229/c3b50fec/attachment-0002.obj>
Desc: lixo.csv
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200229/c3b50fec/attachment-0003.obj>
