[gdal-dev] Handle geojson bigger than 200MB
Francesco Bartoli
xbartolone at gmail.com
Sat Feb 29 11:07:30 PST 2020
Il 28 feb 2020, 17:49 +0100, Just van den Broecke <justb4 at gmail.com>, ha scritto:
> On 28-02-20 17:29, Even Rouault wrote:
> > On vendredi 28 février 2020 17:22:28 CET Francesco Bartoli wrote:
> > > However, we are using both modules so how can we handle exceptions properly
> > > for both of them?
> AFAIK we only use OGR (vector) currently within pygeoapi, no raster/GDAL
> yet.
We are using both https://github.com/geopython/pygeoapi/blob/9d6322a9733313a98664d65a5d42e119802c3e3b/pygeoapi/provider/ogr.py#L101-L104 even though without any real spatial operation from GDAL
> > You can use both gdal.UseExceptions() and ogr.UseExceptions()
> My bad: in the initial version of the pygeoapi OGRProvider I added
> gdal.UseExceptions() from example code (py-gdalogr-cookbook). Was not
> aware of ogr.UseExceptions()!
> > > Using ogr.UseExceptions() the
> > > call https://github.com/geopython/pygeoapi/pull/372/files#diff-b105ae3f7a36
> > > 059b16bdc16a08071016R361 gives the same result silently without any message
> > > to system output this time.
> > On a quick test, ogr.UseExceptions() does the job for me:
> > $ OGR_GEOJSON_MAX_OBJ_SIZE=0 python
> > > > > from osgeo import ogr
> > > > > ogr.UseExceptions()
> > > > > ds = ogr.Open('poly.geojson')
> > > > > lyr = ds.GetLayer(0)
> > > > > lyr.GetNextFeature()
> > Traceback (most recent call last):
> > File "<stdin>", line 1, in <module>
> > File "/home/even/gdal/git/gdal/gdal/swig/python/build/lib.linux-x86_64-2.7/
> > osgeo/ogr.py", line 1339, in GetNextFeature
> > return _ogr.Layer_GetNextFeature(self, *args)
> > RuntimeError: GeoJSON object too complex, please see the
> > OGR_GEOJSON_MAX_OBJ_SIZE environment option
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200229/e4d88022/attachment.html>
