[gdal-dev] Test Failure Question
Andrew Bell
andrew.bell.ia at gmail.com
Thu Jan 9 12:42:54 PST 2020
On Thu, Jan 9, 2020 at 3:18 PM Even Rouault <even.rouault at spatialys.com>
wrote:
> Andrew,
> > Any ideas what might be going on or what I might look for to fix?
> Did you build GDAL yourself ? Check if you built against internal libtiff
> or
> not ? If you built against internal libtiff, make sure to use
> --with-rename-internal-libtiff-symbols
I didn't set any special options in configure when I built. What happens
in this case? I don't see libtiff in the set of libraries to be linked.
Is it dlopen'ed?
Andrew Bell
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200109/8b15d6ba/attachment.html>
