[gdal-dev] illegal axis orientation combination with GDAL v2.4.4
Even Rouault even.rouault at spatialys.com
Sun Jan 19 12:14:23 PST 2020
On dimanche 19 janvier 2020 19:50:54 CET Andrew C Aitchison wrote:
> GDAL 2.4.4 crashes for me after reporting several
>  	"ERROR 1: illegal axis orientation combination"
> errors with GeoTIFF files from the test suite that succeed with 2.4.3,
> 3.0.2 and 3.0.3.
> I haven't managed to find this error string in the source.
> Any idea what I'm doing wrong in my build ?
Your build is likely linking against different version of libproj
as in a similar case:
http://osgeo-org.1560.x6.nabble.com/gdal-dev-illegal-axis-orientation-combination-when-re-projecting-td5334476.html
check with "ldd .libs/libgdal.so | grep proj"
http://www.spatialys.com
