[gdal-dev] illegal axis orientation combination with GDAL v2.4.4
Andrew C Aitchison andrew at aitchison.me.uk
Sun Jan 19 14:10:14 PST 2020
On Sun, 19 Jan 2020, Even Rouault wrote:
> On dimanche 19 janvier 2020 19:50:54 CET Andrew C Aitchison wrote:
>> GDAL 2.4.4 crashes for me after reporting several
>>  	"ERROR 1: illegal axis orientation combination"
>> errors with GeoTIFF files from the test suite that succeed with 2.4.3,
>> 3.0.2 and 3.0.3.
>> I haven't managed to find this error string in the source.
>> Any idea what I'm doing wrong in my build ?
> Your build is likely linking against different version of libproj
> as in a similar case:
> http://osgeo-org.1560.x6.nabble.com/gdal-dev-illegal-axis-orientation-combination-when-re-projecting-td5334476.html
> check with "ldd .libs/libgdal.so | grep proj"
That was indeed the problem.
Adding  --with-proj=yes to get the config line:
 	./configure  --prefix=/usr/local/gdal2.4.4 --with-poppler --with-proj=yes
did the trick.
Thanks.
