[gdal-dev] New Warnings from GTIFF output
Even Rouault
even.rouault at spatialys.com
Thu Jan 23 11:42:44 PST 2020
On jeudi 23 janvier 2020 14:10:03 CET Brian wrote:
> Strange because the files were created by GDAL I created the COG using
> these steps ( original file is too large it is an georaster export). Do you
> see anything that would introduce the corrupt data? What can be done to fix
> it? I attached each file
(Re-adding the list for concluding this thread)
Thanks for the reproducer. The warning was indeed not legit in that situation.
Just fixed in internal libtiff of GDAL master & libtiff gitlab master
Even
http://www.spatialys.com
