[gdal-dev] A crash with 3..1.1
Even Rouault
even.rouault at spatialys.com
Wed Jul 1 02:34:33 PDT 2020
On mercredi 1 juillet 2020 09:27:33 CEST Joaquim Manuel Freire Luís wrote:
> No, not build directly from source. I believe it's a GDAL supplied by
> Macports but Paul is at Hawaii and sleeping now, so can't confirm. And I
> forgot to mention in previous post. No problem when using GDAL 3.1.0
(same
> origin)
You have to determine if it comes from GDAL itself or its integration in GMT.
For example, does that happen with gdalinfo on a geotiff file with the 3.1.1
build ? FYI, Travis-CI builds of GDAL 3.1.1 with its autotest suite on OSX are
fine.
Try using Valgrind
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200701/8d29ca00/attachment.html>
