[gdal-dev] GDAL 3.1.2 soon to fix issue with GeoTIFF driver / PROJ [was Re: A crash with 3..1.1]
Joaquim Manuel Freire Luís
jluis at ualg.pt
Sat Jul 4 19:05:15 PDT 2020
Thanks Even,
It took quite a bit of work to trick MacOS and Cmake to use a custom GDAL build in the GMT build but now things seem to run smooth again.
Joaquim
Sent: Saturday, July 4, 2020 5:30 PM
To: gdal-dev at lists.osgeo.org
Cc: Joaquim Manuel Freire Luís <jluis at ualg.pt>; Paul Wessel <pwessel at hawaii.edu>
Subject: GDAL 3.1.2 soon to fix issue with GeoTIFF driver / PROJ [was Re: [gdal-dev] A crash with 3..1.1]
I strongly believe that this issue was also reproduced with PostgisRaster in
https://github.com/OSGeo/gdal/issues/2744. The key to reproduce it is a call to OSRCleanup() before using the GeoTIFF driver.
I've now a fix for #2744 queued in https://github.com/OSGeo/gdal/pull/2746, and I believe it should fix the GMT issue (I would appreciate confirmation of that)
Due to the issue affecting several downstream programs, I intend to release a 3.1.2 release next tuesday, unless there are other critical issues found in between that need to be adressed
Even
On mercredi 1 juillet 2020 08:25:21 CEST Joaquim Manuel Freire Luís wrote:
> Hi Even,
> My colleagues from Mac are getting crashes when using latest 3.1.1 GDAL from
> GMT.
> the crash occurs for example when running a command such as (the @ is a
> recognized flag to GMT that downloads that particular file)
> gmt grdimage -JM6.5i -R0/360/-45/45 -Bag @earth_day_01d > t.ps
> You can see the stack trace at
> https://github.com/GenericMappingTools/gmt/issues/3568
> The crash occurs at line
> https://github.com/GenericMappingTools/gmt/blob/master/src/gmt_gdalread.c#L3
> 39
> which is accessed right after reading the file
> 4
> A strange thing though is that it works fine for me on Windows with a GDAL
> build from master (2 days old).
> Any idea on what might be causing this?
> Thanks
> Joaquim
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200705/b3321ba4/attachment.html>
