[gdal-dev] GRIB SRS sensitive to CHECK_WITH_INVERT_PROJ
Sean Gillies
sean at mapbox.com
Tue Jun 2 14:16:46 PDT 2020
Hi Even,
On Tue, Jun 2, 2020 at 2:43 PM Even Rouault <even.rouault at spatialys.com>
wrote:
> Hi Sean,
> > An empty string is printed to the terminal after the second warning. Note
> > that behavior was different with rasterio 1.1.4, which
> > set CHECK_WITH_INVERT_PROJ=YES internally in an attempt to improve the
> > defaults.
> > The warning comes from
> https://github.com/OSGeo/gdal/blob/2818ff0a49f65741a55b9cea79df496cc05f85e3/
> > gdal/frmts/grib/gribdataset.cpp#L2149 .
> > Is this sensitivity expected?
> I'd say this isn't completely unexpected if the corners of the dataset are
> far from the projection center. There might be convergence issues in the
> inverse projection method (or it might not try to converge down to the
> precision we expect with CHECK_WITH_INVERT_PROJ=YES)
> CHECK_WITH_INVERT_PROJ is mostly a gdalwarp implementation detail to make
> things work in some cases. I wouldn't advise to use it universally unless
> you know you need to use it (one good reason is that not all PROJ
> projection methods have an inverse method, even if most popular ones do
> have one)
> Even
Got it. Thank you!
Sean Gillies
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200602/e70cb166/attachment.html>
