[gdal-dev] Help request for data alignment issue
jratike80
jukka.rahkonen at maanmittauslaitos.fi
Wed Jun 17 10:23:50 PDT 2020
You do not give enough details so I could try to follow your steps. It is
odd that gdal_edit does not give the desired result. But have you tried to
use "GEOTIFF_KEYS_FLAVOR"="ESRI_PE" directly as a gdalwarp creation option?
-Jukka Rahkonen-
Jessica Evans wrote
> Hi
> Wondering if anyone can help.
> I am currently trying to use osgeo gdal.Warp to resample and reproject a
> GeoTiff (from EPSG:26916 NAD83 / UTM zone 16N to EPSG:102008 North America
> Albers), but also to get the data to align with other data that has been
> processed using ArcGIS.
> I can get the data to align if I first translate the GeoTiff, setting
> "GEOTIFF_KEYS_FLAVOR"="ESRI_PE" creation option and create a new file,
> then run the warp operation on this new file.
> What is the best way to force the alignment with ArcGIS data without
> creating this intermediate file? This will need to be run on files that
> are several tens of GBs in size, so I want to avoid making lots of copies
> of huge files.
> I have tried going via a VRT, but the GEOTIFF_KEYS_FLAVOR option is only
> available for GeoTiffs. I've also tried using gdal_edit to manually edit
> the projection WKT in place and then pass that through gdalwarp, but this
> does not align the data. Editing the projection WKT with gdal_translate to
> create a new tiff for the warp operation seems to work just fine, but like
> I said I'd like to avoid creating new file because of their size.
> I realise the most obvious answer is not to use ArcGIS, but that isn't an
> option for us at the moment.
> Any help on this would be greatly appreciated.
> Thanks in advance,
> Jessica
> [JBA COVID-19
> statement]<https://www.jbagroup.co.uk/sites/www.jbagroup.co.uk/files/documents/15-030%20JBA%20Business%20Continuity%20Briefing%20-%20Latest.pdf>
> T +44 (0) 1756 799919
> www.jbarisk.com<http://www.jbarisk.com>
> [Visit our website]<http://www.jbarisk.com>
> [http://www.jbagroup.co.uk/imgstore/JBA-Email-Sig-Icons-LINKEDIN.png]
> [Follow us on Twitter] <https://twitter.com/jbarisk>
> Our postal address and registered office is JBA Risk Management Limited, 1
> Broughton Park, Old Lane North, Broughton, Skipton, North Yorkshire BD23
> 3FD.
> Find out more about us here:
> www.jbarisk.com<http://www.jbarisk.com/> and follow us on Twitter
> @JBARisk<http://twitter.com/JBARisk> and
> LinkedIn<https://www.linkedin.com/company/2370847?trk=tyah&trkInfo=clickedVertical%3Acompany%2CclickedEntityId%3A2370847%2Cidx%3A2-1-2%2CtarId%3A1447414259786%2Ctas%3AJBA%20RISK%20MANAGEMENT>
> The JBA Group supports the JBA Trust.
> All JBA Risk Management's email messages contain confidential information
> and are intended only for the individual(s) named. If you are not the
> named addressee you should not disseminate, distribute or copy this
> e-mail.
> Please notify the sender immediately by email if you have received this
> email by mistake and delete this email from your system.
> JBA Risk Management Limited is registered in England, company number
> 07732946, 1 Broughton Park, Old Lane North, Broughton, Skipton, North
> Yorkshire, BD23 3FD, Telephone: +441756799919
> gdal-dev mailing list
> gdal-dev at .osgeo
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
