[gdal-dev] Using ReadXMLToList with debian's package
Even Rouault even.rouault at spatialys.com
Mon Jun 22 12:17:38 PDT 2020
Julien,
> I am using the "ReadXMLToList" method from the "GDALMDReaderBase" class[1].
> In my development environment (with GDAL compiled by myself), it works
> perfectly. But when want to compile my application on debian using the
> package libgdal-dev[2], the linker can't find the symbols related to the
> "GDALMDReaderBase" class. Do you know why "libgdal.so" from debian's package
> doesn't contain all the symbols ?
It uses the --with-hide-internal-symbols switch to avoid exporting non-public symbols, such as
the ones of GDALMDReaderBase, which is an implementation detail of GDAL
> Don't you think that "ReadXMLToList",
> which is a static method,
(it isn't actually a static method) As far as I can see, you can get the result of the parsing of
those XML side-car files, mainly in the "IMD" metadata domain of the dataset
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200622/c382c5f8/attachment.html>
