[gdal-dev] Using ReadXMLToList with debian's package
Julien Osman
julien.osman at csgroup.eu
Tue Jun 23 04:31:53 PDT 2020
Dear Even,
Thank you for your answer.
> > I am using the "ReadXMLToList" method from the "GDALMDReaderBase"
> class[1].
> > In my development environment (with GDAL compiled by myself), it works
> > perfectly. But when want to compile my application on debian using the
> > package libgdal-dev[2], the linker can't find the symbols related to the
> > "GDALMDReaderBase" class. Do you know why "libgdal.so" from debian's
> package
> > doesn't contain all the symbols ?
> It uses the --with-hide-internal-symbols switch to avoid exporting
> non-public symbols, such as the ones of GDALMDReaderBase, which is an
> implementation detail of GDAL
This "implementation detail" could be used in other contexts. I
understand GDAL doesn't have for purpose to provide a XML parser. But
this function is used to convert a XML file to a StringList, which is a
GDAL object. I think it would make sens to make that function accessible.
> > Don't you think that "ReadXMLToList",
> > which is a static method,
> (it isn't actually a static method) As far as I can see, you can get
> the result of the parsing of those XML side-car files, mainly in the
> "IMD" metadata domain of the dataset
You are right, this is not a static method. However, it only depends on
the class method "AddXMLNameValueToList" which is defined by a single
line of code. So, this method could easily be made static.
Anyway, I leave this to your good judgement, and I will adapt according
to your decision.
Best regards. Julien :)
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200623/f9df7fdd/attachment.html>
