[gdal-dev] Problems loading swedish climate data to PostGIS
Bo Victor Thomsen
bo.victor.thomsen at gmail.com
Tue Jun 23 01:11:09 PDT 2020
Try change the line:
"PG:host='/var/run/postgresql' port='6543' dbname='sverige'
user='sverige'" \
to:
"PG:host='localhost' port='6543' dbname='sverige' user='sverige'" \
And:
Is port really 6543, not 5432 ?
What about the password ?, i.e something like: "PG:host='localhost'
port='6543' dbname='sverige' user='sverige' password='supersecret'" \
Med venlig hilsen / Kind regards
Bo Victor Thomsen
Den 23-06-2020 kl. 09:27 skrev Thiemo Kellner:
> Hi
> I am new to spacial data processing. For a project of mine I try to
> load swedish climate data in to my PostGIS installation running/using
> an openSUSE Tumbleweed installation.
> I downloaded the data from
> https://www.smhi.se/pd/klimat/rcp_scenario/scid/SCID_v4.0.gdb.zip
> unzipped it and tried to load the data by
> ogr2ogr –f "PostgreSQL" \
> -overwrite \
> –progress \
> --config PG_USE_COPY YES \
> user='sverige'" \
> SCID_v4.0.gdb/gdb
> But I receive the error "Unable to open datasource `PostgreSQL' with
> the following drivers." (Find the full error message at the bottom.
> I tried to outsmart by workaround over shp file
> ogr2ogr –f "ESRI Shapefile" \
> -overwrite \
> –progress \
> SCID_v4.0.gdb/gdb.shp \
> SCID_v4.0.gdb/gdb
> but have been thwarted receiving the analogous error there too.
> I would appreciate help a great deal.
> Kind regards
> Thiemo
> FAILURE:
> Unable to open datasource `PostgreSQL' with the following drivers.
> -> `PCIDSK'
> -> `netCDF'
> -> `PDS4'
> -> `JP2OpenJPEG'
> -> `PDF'
> -> `MBTiles'
> -> `EEDA'
> -> `ESRI Shapefile'
> -> `MapInfo File'
> -> `UK .NTF'
> -> `OGR_SDTS'
> -> `S57'
> -> `DGN'
> -> `OGR_VRT'
> -> `REC'
> -> `Memory'
> -> `BNA'
> -> `CSV'
> -> `NAS'
> -> `GML'
> -> `GPX'
> -> `KML'
> -> `GeoJSON'
> -> `GeoJSONSeq'
> -> `ESRIJSON'
> -> `TopoJSON'
> -> `Interlis 1'
> -> `Interlis 2'
> -> `OGR_GMT'
> -> `GPKG'
> -> `SQLite'
> -> `ODBC'
> -> `WAsP'
> -> `PGeo'
> -> `MSSQLSpatial'
> -> `PostgreSQL'
> -> `MySQL'
> -> `OpenFileGDB'
> -> `XPlane'
> -> `DXF'
> -> `CAD'
> -> `Geoconcept'
> -> `GeoRSS'
> -> `GPSTrackMaker'
> -> `VFK'
> -> `PGDUMP'
> -> `OSM'
> -> `GPSBabel'
> -> `SUA'
> -> `OpenAir'
> -> `OGR_PDS'
> -> `WFS'
> -> `WFS3'
> -> `HTF'
> -> `AeronavFAA'
> -> `Geomedia'
> -> `EDIGEO'
> -> `GFT'
> -> `SVG'
> -> `CouchDB'
> -> `Cloudant'
> -> `Idrisi'
> -> `ARCGEN'
> -> `SEGUKOOA'
> -> `SEGY'
> -> `XLS'
> -> `ODS'
> -> `XLSX'
> -> `ElasticSearch'
> -> `Walk'
> -> `Carto'
> -> `AmigoCloud'
> -> `SXF'
> -> `Selafin'
> -> `JML'
> -> `PLSCENES'
> -> `CSW'
> -> `VDV'
> -> `GMLAS'
> -> `MVT'
> -> `TIGER'
> -> `AVCBin'
> -> `AVCE00'
> -> `NGW'
> -> `HTTP'
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200623/b3b750d9/attachment-0001.html>
