[gdal-dev] Problems loading swedish climate data to PostGIS
Thiemo Kellner thiemo at gelassene-pferde.biz
Tue Jun 23 02:24:38 PDT 2020
  Hei Bo
Thanks for your suggestions. Unfortunately without effect.
The port is ok. I made a parallel PostgreSQL instance on a external
HDD. I tryed to use socket for efficiency. I use .pgpass file because
I am lazy . However, even when giving the password explicitely the
result is the same.
I checked the DB log and I do not see the command hitting the database...
Hjertelig hilsen
Thiemo
Quoting Bo Victor Thomsen <bo.victor.thomsen at gmail.com>:
> Try change the line:
>   "PG:host='/var/run/postgresql' port='6543' dbname='sverige'
> user='sverige'" \
>   to:
>   "PG:host='localhost' port='6543' dbname='sverige' user='sverige'" \
>   And:
>   Is port really 6543, not 5432 ?
>   What about the password ?, i.e something like:
> password='supersecret'" \
> --  Med venlig hilsen / Kind regards  Bo Victor Thomsen
  S/MIME Public Key:
https://oc.gelassene-pferde.biz/index.php/s/eJuAUFONag6ofnH
Signal (Safer than WhatsApp): +49 1578 7723737
Handys: +41 78 947 36 21 | +49 1578 772 37 37
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200623/5d59845c/attachment.html>
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200623/5d59845c/attachment.gif>
Type: application/pkcs7-signature
Desc: S/MIME Signature
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200623/5d59845c/attachment.bin>
