[gdal-dev] Problems loading swedish climate data to PostGIS
Thiemo Kellner thiemo at gelassene-pferde.biz
Tue Jun 23 16:56:45 PDT 2020
  Hei Bo
Well, I is just a project for myself so I made sverige superuser. :o)
Well again, I have on both ports PostGIS running but the 6543 has much
much more space. 5432 is on a small SSD so  I moved from it to an
externel HDD.
As mentionned in the previous post, Thomas was right. I copied options
from the documentation PDF and unfortunately there it was not a dash.
So fixing this, made it run perfectly well.
Takker for hjelp.
Hjertelig hilsen
Thiemo
Quoting Bo Victor Thomsen <bo.victor.thomsen at gmail.com>:
> Thimo -
>   The ogr2ogr command from your reply contains an factual error:
>   thiemo @ thiemos-toshi /mnt/schweden % ogr2ogr –f "PostgreSQL"
> -overwrite –progress --config PG_USE_COPY YES
> PG:"host='/var/run/postgresql' port='5432' dbname='sverige'
> user='sverige'" SCID_v4.0.gdb
>   should be:
> PG:"host='/var/run/postgresql' PORT='6543' dbname='sverige'
>   Anther question: Has the postgresql user 'sverige' the necessary
> write/create rights to the database / schema ?
  S/MIME Public Key:
https://oc.gelassene-pferde.biz/index.php/s/eJuAUFONag6ofnH
Signal (Safer than WhatsApp): +49 1578 7723737
Handys: +41 78 947 36 21 | +49 1578 772 37 37
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200624/7923319c/attachment-0001.html>
Type: application/pkcs7-signature
Desc: S/MIME Signature
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200624/7923319c/attachment-0001.bin>
