[gdal-dev] Problems loading swedish climate data to PostGIS
Bo Victor Thomsen
bo.victor.thomsen at gmail.com
Tue Jun 23 14:39:04 PDT 2020
Thimo -
The ogr2ogr command from your reply contains an factual error:
thiemo @ thiemos-toshi /mnt/schweden % ogr2ogr –f "PostgreSQL"
-overwrite –progress --config PG_USE_COPY YES
PG:"host='/var/run/postgresql' port='5432' dbname='sverige'
user='sverige'" SCID_v4.0.gdb
should be:
PG:"host='/var/run/postgresql' *port='6543*' dbname='sverige'
Anther question: Has the postgresql user 'sverige' the necessary
write/create rights to the database / schema ?
Den 23-06-2020 kl. 22:35 skrev Thiemo Kellner:
> HBVSv_intrans_HQloc100_rcp85_ensembleMean_diffPerc
> FAILURE:
> Unable to open datasource `PostgreSQL' with the following drivers.
> -> `PCIDSK'
> # UNABLE TO USE ogr2ogr TO WRITE DATA TO MY PostGIS
Med venlig hilsen / Kind regards
Bo Victor Thomsen
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200623/2896d558/attachment.html>
