[gdal-dev] Cannot compile 3.1.0 in Centos 7
Even Rouault even.rouault at spatialys.com
Sat Jun 27 13:57:14 PDT 2020
On samedi 27 juin 2020 13:51:40 CEST Doug Niven wrote:
> Even, thanks for the reply! Am hoping contents below contain the smoking
> gun.
This is an issue with linking to libkml libraries
Perhaps try to set LD_LIBRARY_PATH=/usr/local/lib ?
Or if you don't need libkml, ./configure --without-libkml
(you need to "make clean" before rebuilding if you change the options of ./
configure)
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200627/b6a9803b/attachment.html>
