[gdal-dev] Cannot compile 3.1.0 in Centos 7
Doug Niven
dniven at ucsc.edu
Sat Jun 27 13:51:40 PDT 2020
Even, thanks for the reply! Am hoping contents below contain the smoking gun.
collect2: error: ld returned 1 exit status
make[1]: *** [gdalinfo] Error 1
make[1]: *** Waiting for unfinished jobs....
/home/socsciadmin/gdal-3.1.0/.libs/libgdal.so: undefined reference to `kmldom::SerializePretty[abi:cxx11](boost::intrusive_ptr<kmldom::Element> const&)'
/home/socsciadmin/gdal-3.1.0/.libs/libgdal.so: undefined reference to `kmldom::Parse(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >*)'
/home/socsciadmin/gdal-3.1.0/.libs/libgdal.so: undefined reference to `kmlengine::KmzFile::ReadKmlAndGetPath(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >*, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >*) const'
/home/socsciadmin/gdal-3.1.0/.libs/libgdal.so: undefined reference to `kmldom::ParseNS(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >*)'
/home/socsciadmin/gdal-3.1.0/.libs/libgdal.so: undefined reference to `kmlengine::KmzFile::ReadFile(char const*, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >*) const'
/home/socsciadmin/gdal-3.1.0/.libs/libgdal.so: undefined reference to `kmlengine::KmzFile::OpenFromString(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
/home/socsciadmin/gdal-3.1.0/.libs/libgdal.so: undefined reference to `kmlengine::Href::Parse(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&)'
make[1]: *** [gdalserver] Error 1
make[1]: *** [gdal_translate] Error 1
make[1]: *** [gdaladdo] Error 1
make[1]: Leaving directory `/home/socsciadmin/gdal-3.1.0/apps'
make: *** [apps-target] Error 2
> On Jun 27, 2020, at 1:39 PM, Even Rouault <even.rouault at spatialys.com> wrote:
> Doug,
> > My compile.log contents are at very bottom (apologies for its length),
> This is just the configure log, not the build log
> > but
> > after make, I see:
> > make[1]: Leaving directory `/home/socsciadmin/gdal-3.1.0/apps’
> You need to dig a bit more before in the build log and find line(s) containing "error: "
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
