[gdal-dev] Cannot compile 3.1.0 in Centos 7
Even Rouault even.rouault at spatialys.com
Sat Jun 27 13:39:04 PDT 2020
Doug,
> My compile.log contents are at very bottom (apologies for its length),
This is just the configure log, not the build log
> but
> after make, I see:
>    collect2: error: ld returned 1 exit status
>    make[1]: *** [gdalserver] Error 1
>    make[1]: Leaving directory `/home/socsciadmin/gdal-3.1.0/apps’
>    make: *** [apps-target] Error 2
You need to dig a bit more before in the build log and find line(s) containing "error: "
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200627/8c8210c5/attachment-0001.html>
