[gdal-dev] Problems with latest pdfium
Even Rouault even.rouault at spatialys.com
Mon Jun 29 02:34:00 PDT 2020
William,
> I'm getting multiple errors trying to compile PDF support with pdfium.
See https://gdal.org/drivers/raster/pdf.html#pdfium
You need to build pdfium from the indicated forks.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200629/40b79579/attachment.html>
