[gdal-dev] Problems with latest pdfium
William Kyngesburye
woklist at kyngchaos.com
Mon Jun 29 07:26:23 PDT 2020
I'm compiling GDAL 3.1, the note says that only needs the patches. It doesn't specify the source to use.
William Kyngesburye
<kyngchaos at kyngchaos.com>
<http://www.kyngchaos.com>
Don't Panic
> On Jun 29, 2020, at 4:34 AM, Even Rouault <even.rouault at spatialys.com> wrote:
> William,
>> I'm getting multiple errors trying to compile PDF support with pdfium.
> See https://gdal.org/drivers/raster/pdf.html#pdfium
> You need to build pdfium from the indicated forks.
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
