[gdal-dev] Problems with latest pdfium
Even Rouault
even.rouault at spatialys.com
Mon Jun 29 08:10:41 PDT 2020
On lundi 29 juin 2020 09:26:23 CEST William Kyngesburye wrote:
> I'm compiling GDAL 3.1, the note says that only needs the patches. It
> doesn't specify the source to use.
So you need to use
https://github.com/rouault/pdfium_build_gdal_3_1
I presume you'll have to start from the Linux build script & patch and adapt it for the
Mac.
build_linux.sh does the checkout of the revision of PDFium with which this was tested
and applies code.patch and build_linux.patch
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200629/a7e775af/attachment.html>
