[gdal-dev] netcdf warnings
Joaquim Manuel Freire Luís
jluis at ualg.pt
Sun Mar 1 13:18:52 PST 2020
> Thanks for reporting. This turned out to be a regression in master, in raster
> Create() support, related to the addition of CF-1.8 Simple Geometries writing.
> Now fixed
Thanks, works silently now.
>> I see that the x,y coordinates are always named "lon,lat" but data is
>> not in geographics those names are not true.
> GDAL defaults to geographic coordinates, if there's no explicit setting of the CRS. As far as I can see in > CF conventions, there's no way to define a unspecified projected coordinate systems, and as the
> driver stick to CF conventions, that's the likely reason for the current behaviour.
OK.
Joaquim
