[gdal-dev] Convert TIF to BIL
Bret Johnson
bret.johnson at utcg.com
Fri Mar 6 10:35:12 PST 2020
I have some GeoTIFF (.TIF) files that a program I'm using won't accept. It will accept .BIL files and I'm using GDAL to try and do the conversion. When I do, GDAL_TRANSLATE says it worked and it generates a few files (including a .BIL), but it doesn't create the .BLW file where all of the "real" data should be. Is there some special GDAL_TRANSLATE option or use or some special format GeoTIFF data needs to be in for it to work properly and generate a .BLW file?
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200306/55710982/attachment.html>
