[gdal-dev] Convert TIF to BIL
Even Rouault even.rouault at spatialys.com
Fri Mar 6 12:14:35 PST 2020
Bret,
> I have some GeoTIFF (.TIF) files that a program I'm using won't accept.  It
> will accept .BIL files and I'm using GDAL to try and do the conversion.
> When I do, GDAL_TRANSLATE says it worked and it generates a few files
> (including a .BIL), but it doesn't create the .BLW file where all of the
> "real" data should be.  Is there some special GDAL_TRANSLATE option or use
> or some special format GeoTIFF data needs to be in for it to work properly
> and generate a .BLW file?
I don't know which output driver you use (EHdr, ENVI etc.), but they aren't
likely to produce a .blw worldfile as they will generate a text header file
specific to the format.
To generate a .blw file you can do:
gdal_translate your_input.tif tmp.tif -co TFW=YES
This will generate a tmp.tfw file. Just rename it to .blw and with the
basename of your BIL output file.
Even
http://www.spatialys.com
