[gdal-dev] Convert TIF to BIL
Bret Johnson
bret.johnson at utcg.com
Fri Mar 6 16:19:23 PST 2020
Even:
Thanks. That worked to create a World file, so I made it past the error message. It's still not importing correctly and the error message is so generic that it's useless (basically just says it doesn't like the data). I'll do some more playing.
-----Original Message-----
Sent: Friday, March 6, 2020 1:15 PM
To: gdal-dev at lists.osgeo.org
Cc: Bret Johnson <bret.johnson at utcg.com>
Subject: Re: [gdal-dev] Convert TIF to BIL
Bret,
> I have some GeoTIFF (.TIF) files that a program I'm using won't
> accept. It will accept .BIL files and I'm using GDAL to try and do the conversion.
> When I do, GDAL_TRANSLATE says it worked and it generates a few files
> (including a .BIL), but it doesn't create the .BLW file where all of
> the "real" data should be. Is there some special GDAL_TRANSLATE
> option or use or some special format GeoTIFF data needs to be in for
> it to work properly and generate a .BLW file?
I don't know which output driver you use (EHdr, ENVI etc.), but they aren't likely to produce a .blw worldfile as they will generate a text header file specific to the format.
To generate a .blw file you can do:
gdal_translate your_input.tif tmp.tif -co TFW=YES
This will generate a tmp.tfw file. Just rename it to .blw and with the basename of your BIL output file.
Even
Spatialys - Geospatial professional services http://www.spatialys.com
