[gdal-dev] Infinite loop Netcdf/HDF5 -geoloc when warping (version 2.4.4)
Menno van Scheers - HUSS
menno at huss.nl
Thu Mar 12 09:14:17 PDT 2020
Hi Even,
First thanks for the speedy reply.
We have used a couple of different version and packages to test this (So a complete gdal update with the associated libhdf5 and netcdf).
In the project itself (.NET) we used 2 different version from the gdal package https://www.nuget.org/packages/GDAL/ (2.4.4 and 2.43)
For testing on commandline I downloaded the prebuild package from http://www.gisinternals.com/release.php
This was also reproduced on a completely clean machine with no prior GDAL or other dependencies installed.
Best Regards,
Menno Van Scheers
-----Oorspronkelijk bericht-----
Van: Even Rouault <even.rouault at spatialys.com>
Verzonden: donderdag 12 maart 2020 15:31
Aan: gdal-dev at lists.osgeo.org
CC: Menno van Scheers - HUSS <menno at huss.nl>; Mauricio Dominguez Diaz Del Castillo <Mauricio.Dominguez at rtl.nl>
Onderwerp: Re: [gdal-dev] Infinite loop Netcdf/HDF5 -geoloc when warping (version 2.4.4)
Menno,
did you just update GDAL or GDAL+libnetcdf/libhdf5 ? I can't replicate the error you see with GDAL 2.4 or master, and libhdf5 1.8.16 from Ubuntu 16.04
I've tried on ftp://msgcpp-ogc-realtime.knmi.nl/
SEVIR_OPER_R___MSGCPP__L2__20200305T000000_20200305T001500_0001.nc
By the way the georeferencing of that product is broken (but that's unrelated to the issue you get):
projection:semi_major_axis = 6356584.f ;
projection:semi_minor_axis = 6378169.f ;
semi_minor_axis should be <= semi_major_axis, not greater
Even
Spatialys - Geospatial professional services http://www.spatialys.com
