[gdal-dev] Infinite loop Netcdf/HDF5 -geoloc when warping (version 2.4.4)
Even Rouault
even.rouault at spatialys.com
Thu Mar 12 07:31:06 PDT 2020
Menno,
did you just update GDAL or GDAL+libnetcdf/libhdf5 ? I can't replicate the
error you see with GDAL 2.4 or master, and libhdf5 1.8.16 from Ubuntu 16.04
I've tried on ftp://msgcpp-ogc-realtime.knmi.nl/
SEVIR_OPER_R___MSGCPP__L2__20200305T000000_20200305T001500_0001.nc
By the way the georeferencing of that product is broken (but that's unrelated
to the issue you get):
projection:semi_major_axis = 6356584.f ;
projection:semi_minor_axis = 6378169.f ;
semi_minor_axis should be <= semi_major_axis, not greater
Even
http://www.spatialys.com
