[gdal-dev] cannot write to gdal_array
Even Rouault
even.rouault at spatialys.com
Fri Mar 13 10:01:31 PDT 2020
On vendredi 13 mars 2020 16:23:27 CET Jon Morris wrote:
> Thanks for the quick fix, Even! Glad it wasn't just something I'd missed.
> I'm not entirely clear on the uses for gdal_array. Are there cases where it
> is better than using a MEM raster?
I don't think so. It uses the MEM driver underneath. This is just a matter of
using different entry points to the same backend.
> Is there any more detailed documentation?
Not sure. Documentation is not the strongest point of the bindings :-) Looking
at unit tests / using the search function in the github repo is sometimes
useful to find relevant snippets.
Even
http://www.spatialys.com
