[gdal-dev] Building on windows
Darrel Maddy
darrel.maddy at newcastle.ac.uk
Tue Mar 24 03:50:03 PDT 2020
Not having much luck here. Anyone got any further suggestions?
I turned to windows because of a problem with my linux build - this is throwing up errors such as
/usr/lib/gcc/x86_64-linux-gnu/7/include/avx512fintrin.h(1761): error: identifier "__builtin_ia32_sqrtsd_round" is undefined
/usr/lib/gcc/x86_64-linux-gnu/7/include/avx512fintrin.h(1770): error: identifier "__builtin_ia32_sqrtss_round" is undefined
eclipse indicates these errors are being thrown during access to gdal.h . This program compiled and ran without error until last week. I have not done anything to the gdal library or updated anything that I am aware of. I will move back to linux if I can resolve this issue so any suggestions for this would also be welcome.
If I cannot resolve these then I will move away from gdal as a general library and write some generic data access tools.
Thanks
Darrel
Sent: 17 March 2020 15:10
To: Jerome Siot <jerome.siot at mytimezero.com>; 'gdal-dev at lists.osgeo.org' <gdal-dev at lists.osgeo.org>
Subject: RE: Building on windows
Dear Jérome
Many thanks for trying to help. Alas it is giving the same errors in the Developer Command Prompt window.
Darrel
Sent: 17 March 2020 15:05
To: Darrel Maddy <darrel.maddy at newcastle.ac.uk>; 'gdal-dev at lists.osgeo.org' <gdal-dev at lists.osgeo.org>
Hello,
* Be sure to launch a terminal by executing :
C:\Program Files (x86)\Microsoft Visual Studio\2019\Enterprise\Common7\Tools\LaunchDevCmd.bat
* Then , give the VS version in nmake command :
nmake /f makefile.vc MSVC_VER=1900
Hope this helps, Jérome
De : gdal-dev <gdal-dev-bounces at lists.osgeo.org<mailto:gdal-dev-bounces at lists.osgeo.org>> De la part de Darrel Maddy
Envoyé : Sunday, March 15, 2020 1:08 PM
À : 'gdal-dev at lists.osgeo.org' <gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>>
Objet : [gdal-dev] Building on windows
I have recently switched back to windows for a specific project that uses the gdal library. I am getting the following error on compilation of the VS project
NMAKE : fatal error U1077: '"C:\Program Files (x86)\Microsoft Visual Studio\2019\Enterprise\VC\Tools\MSVC\14.22.27905\bin\HostX86\x64\cl.EXE"' : return code '0x2'
The cl.exe file is present in the directory (there are a number of similar messages that follow) and I am unsure how to proceed. Any suggestions?
Thanks
Darrel
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200324/ee954f24/attachment.html>
