[gdal-dev] S-57 driver Generic attribute DSNM
Andreas Oxenstierna
ao at t-kartor.se
Sun May 3 00:39:44 PDT 2020
Hi
I have not checked the GDAL implementation but DSNM is an unneccessary
addition to the S57 spec to generate a (potential unique) GUID.
S57 spec has no GUID definition, IDs needs only be to unique inside a
dataset/ENC cell.
DSNM belongs to the dataset-wide DSID fields, see 6.3.2 in
https://iho.int/uploads/user/pubs/standards/s-57/20ApB1.pdf
> Hello,
> After reading this documentation concerning the S-57 driver :
> https://gdal.org/drivers/vector/s57.html
> I thought the attribute DSNM ( Dataset name) should be defined on all features, no ?
> But on the source code, the method S57GenerateStandardAttributes (s57featuredefns.cpp) always attaches theses standard feature attributes :
> GRUP, OBJL, RVER, AGEN, FIDN, FIDS but there is no mention of the DSNM attribute.
> Is it a mistake in the documentation? In the code? Or just a misunderstanding on my side?
> Thank you for your clarification,
> -- loïc
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Best Regards
Andreas Oxenstierna
T-Kartor Geospatial AB
Olof Mohlins väg 12 Kristianstad
mobile: +46 733 206831
mailto: ao at t-kartor.se
http://www.t-kartor.com
