[gdal-dev] GDAL 3.1.0 RC2 available
Sebastiaan Couwenberg sebastic at xs4all.nl
Sun May 3 10:50:17 PDT 2020
On 5/3/20 7:36 PM, Edzer Pebesma wrote:
> In the r-cran-sf logs, I find:
> autopkgtest [09:48:59]: build not needed
> But if a new version of GDAL was just installed, a build would have been
> needed (assuming we use dynamic linking).
GDAL did not bump the SONAME, so it claims to be ABI compatible with the
version the r-cran packages were built with. Rebuilding should not be
required. Or is this an R thing I'm not familiar with?
Kind Regards,
Bas
 GPG Key ID: 4096R/6750F10AE88D4AF1
Fingerprint: 8182 DE41 7056 408D 6146  50D1 6750 F10A E88D 4AF1
