[gdal-dev] New to Gdal and NITF
Thomas Juntunen junt0015 at umn.edu
Thu May 7 07:12:27 PDT 2020
NITF is a format designed to wrap various metadata sets into a package with
some number of raster layers. It isn't necessarily straightforward to
build. I suggest you have a look at the specifications:
https://gwg.nga.mil/ntb/baseline/documents.html
There's also a Wikipedia article that provides a decent summary:
https://en.wikipedia.org/wiki/National_Imagery_Transmission_Format
I don't use C# but there's an example in the GDAL/OGR Python cookbook that
worked for me (I used the NITF driver instead of the GTiff):
https://pcjericks.github.io/py-gdalogr-cookbook/raster_layers.html?highlight=rasterize#create-raster-from-array
Good luck,
Thomas
On Thu, May 7, 2020 at 8:47 AM RejectKid <RejectKid at gmail.com> wrote:
> It's hard to say what ive tried as I don't even know where to start
> really.
> I was expecting something like "new Nitf()" or "Nitf.Create()" style api
> and
> I'm not seeing those.
> I'm guessing I'm supposed to do something with the Gdal.Open() method but I
> dont know what I'd actually pass in there.  is the utf8_path a file path?
> and what file formats does that read in? or is there a way to read in bytes
> of an image?
> as you can tell im kinda lost on how to even start reading anything in
> using
> the GDAL nuget.  so any help/getting started would be great
> Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
*The right coordinate system can turn an impossible problem into two really
hard problems. -- Charlie Pellerin*
Thomas Juntunen
GIS Specialist
Polar Geospatial Center
R280 Learning and Environmental Science
1954 Buford Ave
University of Minnesota
St. Paul, MN 55108
612-626-0505
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200507/867dc0d5/attachment.html>
