[gdal-dev] gdal_viewshed
Rahkonen Jukka (MML)
jukka.rahkonen at maanmittauslaitos.fi
Fri May 8 02:57:08 PDT 2020
Hi Pedro,
You wrote that you used this command in your test
gdal_viewshed -b 1 -md 28000.0 -ox -41597.922 -oy 71254.049 -oz 21.6 -tz
10.0 -vv 1 -cc 0.85714 -f GTiff path_to_mdt.tif path_to_output.tif
Could you also give a link to "path_to_mdt.tif" or repeat the test with some other DEM that other users can access with a direct link? Also showing the exact parameters that you used with other software would help lazy people like me to catch the challenge.
I wonder if your DEM is using scaling and offset and somehow gdal_viewshed believes that the observer and target are much higher. Gdalinfo about the DEM would help.
I started a new thread intentionally because the discussion started in a renamed "GDAL 3.1.0 is released" thread.
-Jukka Rahkonen-
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200508/2ab0d91b/attachment.html>
