[gdal-dev] gdal_viewshed
    Pedro Venâncio
    pedrongvenancio at gmail.com
    Thu May  7 17:31:14 PDT 2020
Hi Eli,
Oh yes, I used the same parameters in all three. The only difference is in
atmospheric refraction and curvature effect, but even playing a bit with
that parameter, the overall effect is minimum compared with the huge
difference I see between gdal_viewshed and the others.
I'm putting Tamas in CC to ask if I'm missing something.
Thanks and best regards!
Pedro
Eli Adam <eadam at co.lincoln.or.us> escreveu no dia sexta, 8/05/2020 à(s)
01:16:
> Hi Pedro,
> On Thu, May 7, 2020 at 4:39 PM Eli Adam <eadam at co.lincoln.or.us> wrote:
> > Was the same done in GRASS and the Visibility Analysis plugin for
> > QGIS?
> This was the main part of my question, that all three had the same
> inputs.  Did GRASS and QGIS have all the same parameters?
> I'm not certain but my impression is that you're using the parameters
> correctly.  Perhaps the author, Tamas will reply.
> Best regards, Eli
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200508/70e8b981/attachment.html>
