[gdal-dev] COG - RGBI
Vincent Sarago
vincent.sarago at gmail.com
Fri May 8 12:12:18 PDT 2020
I guess you mean RGB and I for Infra-red ? Anyway the answer will be NO. JPEG only allow 3 bands + a bit mask (same for Webp).
For raster with more than 3 bands there is no real option to get compression (with loss) as high as with JPEG or WEBP .
> Le 8 mai 2020 à 15:08, Travis Kirstine <traviskirstine at gmail.com> a écrit :
> Is it possible to create RGBI Cloud Optimized Tiffs with JPEG compression?
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
