[gdal-dev] COG - RGBI
Even Rouault even.rouault at spatialys.com
Fri May 8 12:14:26 PDT 2020
On vendredi 8 mai 2020 15:08:36 CEST Travis Kirstine wrote:
> Is it possible to create RGBI Cloud Optimized Tiffs with JPEG
compression?
Possibly. But not with the COG driver, which doesn't offer the option
for that. You should use the old way with the GTiff driver by forcing
-co INTERLEAVE=BAND so that each band is JPEG compressed
separately (since pixel-interleaved JPEG compression is limited to 3
samples)
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200508/effc69a7/attachment-0001.html>
