[gdal-dev] COG - RGBI
Fri May 8 12:14:34 PDT 2020
Travis,
The big benefit of JPEG compression comes with YCbCr color space which I do
not believe can be mixed with a 4 band RGBI product.  So I'm not sure how
one would do this.  One could certainly put the NIR in a distinct directory
in the GeoTIFF, but not many applications would know how to utilize that,
and it would not appear as just a 4th band from the GDAL view of things.
In theory you could do BAND interleaved JPEG and compress each of the 4
bands separately but I do not think you get a great quality/compression
result from this.
I'm also curious if you were wanting to just do 8bit or 12/16bit?
I would love to have a way of distributing 12/16 bit RGBI data with a good
(gentle) lossy compression and good application compatibility in TIFF.
Best regards,
Frank
On Fri, May 8, 2020 at 3:08 PM Travis Kirstine <traviskirstine at gmail.com>
wrote:
> Is it possible to create RGBI Cloud Optimized Tiffs with JPEG compression?
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
I set the clouds in motion - turn up   | Frank Warmerdam,
light and sound - activate the windows | +1 650-701-7823
and watch the world go round - Rush    | Geospatial Software Developer
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200508/c11b8453/attachment.html>
