[gdal-dev] COG - RGBI
Travis Kirstine
traviskirstine at gmail.com
Fri May 8 12:55:12 PDT 2020
Thanks all for the feedback!
Right now we are looking at doing this for only 8bit.
Regards
On Fri, 8 May 2020 at 15:14, Frank Warmerdam <warmerdam at pobox.com> wrote:
> Travis,
> The big benefit of JPEG compression comes with YCbCr color space which I
> do not believe can be mixed with a 4 band RGBI product. So I'm not sure
> how one would do this. One could certainly put the NIR in a distinct
> directory in the GeoTIFF, but not many applications would know how to
> utilize that, and it would not appear as just a 4th band from the GDAL view
> of things.
> In theory you could do BAND interleaved JPEG and compress each of the 4
> bands separately but I do not think you get a great quality/compression
> result from this.
> I'm also curious if you were wanting to just do 8bit or 12/16bit?
> I would love to have a way of distributing 12/16 bit RGBI data with a good
> (gentle) lossy compression and good application compatibility in TIFF.
> Best regards,
> Frank
> On Fri, May 8, 2020 at 3:08 PM Travis Kirstine <traviskirstine at gmail.com>
> wrote:
>> Is it possible to create RGBI Cloud Optimized Tiffs with JPEG compression?
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> I set the clouds in motion - turn up | Frank Warmerdam,
> light and sound - activate the windows | +1 650-701-7823
> and watch the world go round - Rush | Geospatial Software Developer
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200508/c7eb0393/attachment-0001.html>
