[gdal-dev] how to install gdal from source?
Jorge Gustavo Rocha
jgr at osgeopt.pt
Mon May 11 01:36:08 PDT 2020
Hi Sandra,
Are you switch to gdal/gdal? You shouldn't have to add a includedir for
gdal. gdal_version.h is included in the code, at gcore/gdal_version.h
Here my recipe to compile gdal (on Ubuntu):
git clone https://github.com/OSGeo/gdal
cd gdal/gdal
./autogen.sh
./configure --with-python=python3 --with-proj=/usr/local --with-pg=yes
--with-poppler
make -j8
sudo make install
sudo ldconfig
cd swig/python
python3 setup.py build
sudo python3 setup.py install
I hope it helps. Regards,
Jorge Gustavo
On 11/05/20 06:37, Sandra Maksimovic wrote:
> Hi all,
> I’m trying to install GDAL v3.1.0 with Proj v6.2.1 on CentOS 7.7. I am
> continually receiving the following error during the make step:
> ../gdal.h:44:26: fatal error: gdal_version.h: No such file or directory
> #include "gdal_version.h"
> I have tried including the headers from the OS installed version of GDAL
> (v1.11.4) to no avail. Here is my configure line:
> ./configure --prefix=$PREFIX --with-proj=$PROJDIR
> --includedir=/usr/include/gdal --with-threads --with-libtiff=internal
> --with-geotiff=internal --with-jpeg=internal --with-gif=internal
> --with-png=internal --with-libz=internal
> Any ideas?
> Thanks,
> *Sandra Maksimovic*
> Systems Administrator
> Information Technology
> *Murdoch Children’s Research Institute*
> The Royal Children’s Hospital, 50 Flemington Road
> Parkville, Victoria 3052 Australia
> *T *+61 3 8341 6498
> *E *sandra.maksimovic at mcri.edu.au <mailto:sandra.maksimovic at mcri.edu.au>
> *W *mcri.edu.au <https://www.mcri.edu.au/>
> This e-mail and any attachments to it (the "Communication") are, unless
> otherwise stated, confidential, may contain copyright material and is
> for the use only of the intended recipient. If you receive the
> Communication in error, please notify the sender immediately by return
> e-mail, delete the Communication and the return e-mail, and do not read,
> copy, retransmit or otherwise deal with it. Any views expressed in the
> Communication are those of the individual sender only, unless expressly
> stated to be those of Murdoch Children’s Research Institute (MCRI) ABN
> 21 006 566 972 or any of its related entities. MCRI does not accept
> liability in connection with the integrity of or errors in the
> Communication, computer virus, data corruption, interference or delay
> arising from or in respect of the Communication.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
OSGeo Portugal
NIF: 509588190
email: geral at osgeopt.pt
https://www.osgeopt.pt/
Próximo evento: SASIG 2017, 20 a 22 de novembro, Porto
Mais informações: http://osgeopt.pt/sasig2017/
