[gdal-dev] Problem building GDAL with Teigha ODA libraries
Paulo Dias Almeida pda at geomaster.pt
Thu May 14 02:16:28 PDT 2020
Hello,
I was wondering if you could help with a problem I encountered when
building GDAL with the Open Design Alliance Libraries (ODA >= 2021) on
Linux.
I've been trying to build GDAL with ODA version 2021.2 based on the
changes made to build on Windows in the following commit
<https://github.com/OSGeo/gdal/commit/44ce5be4c043eea2fb2bc719858fb62285a5cc03>.
Following those changes I've edited the configure and dwg's GNUmakefile
as seen in the attached diff. However I've run into a linking problem
that I haven't been able to solve. Namely when building the 'gdalinfo'
target I'm getting several 'undefined reference' errors with the built
libgdal.so:
/bin/bash /home/paulo/Dev/gdal/gdal/libtool --mode=link --silent g++
gdalinfo_bin.lo  /home/paulo/Dev/gdal/gdal/libgdal.la  -o gdalinfo
/home/paulo/Dev/gdal/gdal/.libs/libgdal.so: undefined reference to
`OdDgHostAppServices::program()'
`pcre_study'
`OdDgFontTable::getFont(unsigned int) const'
`OdDgDatabase::getNamedViewTable(OdDg::OpenMode) const'
`OdDgGraphicsElementPE::desc()'
`OdDgElement::elementId() const'
`OdDgArc2d::desc()'
`OdDgHostAppServices::getThumbnail(OdString const&, OdBinaryData&)'
collect2: error: ld returned 1 exit status
GNUmakefile:90: recipe for target 'gdalinfo' failed
make[1]: *** [gdalinfo] Error 1
The configure command used for this build was the following:
./configure --with-python=python3 --with-proj=/usr/local --with-pg=yes
--with-teigha=/home/paulo/Dev/oda/21.2/Drawings_lnxX64_7.2dll
--with-teigha-krl=/home/paulo/Dev/oda/21.2/Kernel_lnxX64_7.2dll
--with-teigha-plt=lnxX64_7.2dll
If you could give some insights about this problem it would be greatly
appreciated.
Regards
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200514/e4acd4a2/attachment.html>
Type: text/x-patch
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200514/e4acd4a2/attachment.bin>
