[gdal-dev] Odd Contours
Owen Varley Owen.Varley at inzpire.com
Mon May 18 05:32:05 PDT 2020
Hi all,
I'm seeing some odd contour line points being generated from gdal_contour and I was wondering whether anything else might have seen something similar?
Using gdal_contour -i 15.24 -a height e100n00.dt2 n00.shp on the attached tile (Removed as too large) gives some contours which have points very close together. Take a look at the first three points in the contour line below, there are all < 0.1m of each other which, given the height posts are spaced at 30m's, seems very odd.
Contour Line (381m):
(100.1727777777963, 0.5436111111111112)
(100.17277777777778, 0.5436111111039885)
(100.17277777770833, 0.5436111111111112)
(100.1725, 0.5437345679012346)
(100.17222222222223, 0.5438518518518518)
(100.1720833332639, 0.5438888888888889)
(100.17222222222223, 0.5440277778472222)
(100.1724074074074, 0.5441666666666667)
(100.1725, 0.5442222222222222)
(100.17277777777778, 0.5443888888888889)
(100.17305555555556, 0.5442592592592592)
(100.17314814814816, 0.5441666666666667)
(100.1731944445139, 0.5438888888888889)
(100.17305555555556, 0.5438562091503267)
Related DTED height posts (m):
       [371, 374, 377, 380, 379, 379]
       [376, 379, 382, 385, 382, 379]
       [379, 383, 386, 390, 383, 379]
       [368, 368, 377, 381, 366, 375]
       [364, 357, 347, 342, 329, 345]
Has anyone seen this before or know what is going on? For the majority of other contours the contour points are at least 30m apart.
Kind regards,
Owen
[http://revolutionindefence.com/images/Logobannerwithwarning.png]
This email and any attachments to it may be confidential and are intended solely for the use of the individual to whom it is addressed. If you are not the intended recipient of this email, you must neither take any action based upon its contents, nor copy or show it to anyone. Please contact the sender if you believe you have received this email in error. Inzpire retains personal data relating to our customers and partners for the purposes of conducting a business relationship, communicating and marketing to them as well as to providing invitations to upcoming events. Please see our Privacy Notice <https://www.inzpire.com/privacy-cookie-policy/> for further information. In accordance with our Privacy Notice, you have the right to withdraw your consent at any time. Inzpire may monitor email traffic data and also the content of email for the purposes of security. Inzpire Limited (Registered in England & Wales: Company Number: 05456427) Registered office: Unit 1B, Alpha Court Business Park, Kingsley Road, Lincoln, LN6 3TA. https://www.inzpire.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200518/7cd0878f/attachment.html>
