[gdal-dev] DEM handling in GDAL
Cédric Traizet cedric.traizet at csgroup.eu
Mon May 25 07:22:15 PDT 2020
Hi all,
I am trying to use the GDAL C++ API to read and use DEMs. Is it possible ?
In GDAL source code, in alg/gdal_rpc.cpp, there are several functions
for DEM handling (e.g. GDALRPCGetHeigthAtLongLat that supports several
resampling methods, GDALRPCOpenDEM). These functions are used internally
by the RPC algorithms. However, these DEM processing functions are not
exposed in GDAL API (only the rpc functions are). Is there a reason for
this ? These functions could be useful in other applications than rpc
transformations !
Kind regards,
Cédric
