[gdal-dev] DEM handling in GDAL
Even Rouault even.rouault at spatialys.com
Mon May 25 07:30:53 PDT 2020
On lundi 25 mai 2020 16:22:15 CEST Cédric Traizet wrote:
> Hi all,
> I am trying to use the GDAL C++ API to read and use DEMs. Is it possible ?
> In GDAL source code, in alg/gdal_rpc.cpp, there are several functions
> for DEM handling (e.g. GDALRPCGetHeigthAtLongLat that supports several
> resampling methods, GDALRPCOpenDEM). These functions are used internally
> by the RPC algorithms. However, these DEM processing functions are not
> exposed in GDAL API (only the rpc functions are). Is there a reason for
> this ? These functions could be useful in other applications than rpc
> transformations !
Those routines are DEM specific usages for the RPC transformer. They are implementation
details.
But if you just need to extract elevation values from a DEM, this is exactly the same as
reading pixel values from a generic raster.
Look at https://gdal.org/tutorials/raster_api_tut.html or any documentation related to
reading raster in GDAL.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20200525/1ec8765c/attachment.html>
