[gdal-dev] Best way to get GPU accelerated GDAL binaries?
Arthur Nieuwland
a.nieuwland at sobolt.com
Mon Nov 9 02:40:02 PST 2020
Hello mailing list,
I am trying to use gdalwarp and gdal_translate to do manipulations on a
large raster using a vector file. The process is taking very long (a week
by my estimation), I assume because the raster is large and the vector file
complex.
For that reason I want to accelerate the calculations using GPU/OpenCL
acceleration. What is the best way to get such binaries? Is there maybe a
docker image with such binaries? Or a tgz prebuilt with CUDA/OpenCL support?
I tried compiling it myself with GDAL 2.4.2 on Ubuntu 16.04 with 9.0. While
the compilation failed, running the binaries resulted in a core dump. If
compiling is the best way, what configuration (Linux distro / CUDA version
/ ...) works well?
Lastly, does GPU acceleration help gdalwarp mask faster? The raster is
409600 by 241600 pixels, data type byte with 2 bits. The command I want to
run is:
gdalwarp -cutline <complex gpkg> -srcnodata 3 -dstnodata 3 -co
BIGTIFF=yes -multi -co tiled=yes in.vrt out.tif
To summarize, I'd like to know:
1. Do prebuilt binaries exist with GPU acceleration enabled?
2. If I need to compile them myself, what are the best versions to do so
with?
3. Optionally, will GPU acceleration help me mask my input raster?
Thanks in advance,
Arthur Nieuwland
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20201109/cc2509ad/attachment.html>
