[gdal-dev] armadillo error with homebrew install of ogr2ogr
Sean Gillies
sean at mapbox.com
Tue Nov 10 09:25:33 PST 2020
Hi John,
On Tue, Nov 10, 2020 at 10:14 AM John Muccigrosso <muccigrosso at icloud.com>
wrote:
> I've just started getting this error when I try to use ogr2ogr:
> dyld: Library not loaded: /usr/local/opt/armadillo/lib/libarmadillo.9.dylib
> Referenced from: /usr/local/bin/ogr2ogr
> Reason: image not found
> Presumably this is because armadillo is up to version 10 in my system:
> > ll /usr/local/opt/armadillo/lib/
> total 576
> drwxr-xr-x 6 username staff 192 Oct 28 09:06 .
> drwxr-xr-x 10 username staff 320 Oct 28 09:06 ..
> -r--r--r-- 1 username staff 293580 Oct 28 09:06
> libarmadillo.10.1.1.dylib
> lrwxr-xr-x 1 username staff 25 Oct 28 09:06 libarmadillo.10.dylib
> -> libarmadillo.10.1.1.dylib
> lrwxr-xr-x 1 username staff 21 Oct 28 09:06 libarmadillo.dylib ->
> drwxr-xr-x 3 username staff 96 Oct 28 09:06 pkgconfig
> I've installed goal via homebrew.
> Thanks for any help.
> John
I haven't been a homebrew user in a long time, but I found some discussion
and a possible solution for you in
https://github.com/OSGeo/homebrew-osgeo4mac/issues/456#issuecomment-414220068
If some other homebrew package updated your armadillo library after you
installed gdal, you'll need to reinstall gdal.
Sean Gillies
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20201110/3c93b2f4/attachment.html>
