[gdal-dev] armadillo error with homebrew install of ogr2ogr
Paul Harwood
runette at gmail.com
Wed Nov 11 00:51:32 PST 2020
Have you thought about just using the Conda Installation? Solves most or
all of these problems.
On Tue, 10 Nov 2020 at 17:14, John Muccigrosso <muccigrosso at icloud.com>
wrote:
> I've just started getting this error when I try to use ogr2ogr:
> dyld: Library not loaded: /usr/local/opt/armadillo/lib/libarmadillo.9.dylib
> Referenced from: /usr/local/bin/ogr2ogr
> Reason: image not found
> Presumably this is because armadillo is up to version 10 in my system:
> > ll /usr/local/opt/armadillo/lib/
> total 576
> drwxr-xr-x 6 username staff 192 Oct 28 09:06 .
> drwxr-xr-x 10 username staff 320 Oct 28 09:06 ..
> -r--r--r-- 1 username staff 293580 Oct 28 09:06
> libarmadillo.10.1.1.dylib
> lrwxr-xr-x 1 username staff 25 Oct 28 09:06 libarmadillo.10.dylib
> -> libarmadillo.10.1.1.dylib
> lrwxr-xr-x 1 username staff 21 Oct 28 09:06 libarmadillo.dylib ->
> drwxr-xr-x 3 username staff 96 Oct 28 09:06 pkgconfig
> I've installed goal via homebrew.
> Thanks for any help.
> John
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20201111/2225e7f8/attachment.html>
